Multisim and Ultiboard
Does the autorouter work with a double sided board in Ultiboard Education Edition?
When I set Layer pairs = 1 and Stack-ups = 0 under PCB Properties | Copper layers, I get the error message “Ultiboard Error during autorouter preprocessing. Invalid via definition - must be multiple layers and circular”.
However, if I set Layer pairs = 2 and Stack-ups = 0, the autorouter works just fine.
Is there a way to get the autorouter to work with a simple double sided board?
(4,911 Views)
Hi Kevin,
With the layer pair set to 1, you should be able to route on top/bottom layer.  Have a look at this knowledge base and see if it applies to you:
http://digital.ni.com/public.nsf/allkb/7A814AD0411858BD862575E80037EC51
I don't know why you are getting that error message with the via definition.  Can you post a file with the problem?  I don't need a complete design, delete all the crucial parts on the layout just leave a few parts so that I can autorouter and see where this error is coming from.
Tien P.
(4,895 Views)
Hi Kevin,
Is should not be an issue to route on a simple 2 layer board using the autorouter. Can you send us your files so we can see what could be causing the issue.
Tayyab R,
National Instruments.
(4,892 Views)
I found the following work around to the error when trying to autoroute a double sided board.  Can someone explain why this worked?
To autoroute a double sided board (with error work around):
  1. Open Options | PCB Properties | Copper layers and set the following:
    • Layer pairs = 1
    • Single layer stack-up: Top = 0 and Bottom = 0
    • Set copper top routing: Allow routing | Copper Top | Copper layer: Properties | select Routing
    • Set copper bottom routing: Allow routing | Copper Bottom | Copper layer: Properties | select Routing
    • Select OK
  • Select Autoroute | Start/resume autorouter
  • Do the following if you get the error “Ultiboard Error during autorouter preprocessing. Invalid via definition - must be multiple layers and circular”
    • Disallow routing on EITHER the top or bottom copper layer
      • To unset copper top routing: Allow routing | Copper Top | Copper layer: Properties | unselect Routing
      • To unset copper bottom routing: Allow routing | Copper Bottom | Copper layer: Properties | unselect Routing
    • Immediately select Autoroute | Stop/pause autorouter
    • Allow routing on both the top and bottom copper layer
    • The board now autoroutes without the error noted above.
(4,887 Views)
Hi Kevin,
If you select Options>>PCB Properties>>Copper Layer, increase you layer part to 2, now under Via Support uncheck the "Blind via" checkbox.  Change the layer pair back to 1 and this should fix the router problem.
Ultiboard should recognize that a two layer does not support blind via and the blind via support shoulb be ignored, so I will let R&D know about this issue.
Tien P.
(4,870 Views)
