Multisim and Ultiboard
Doing a TRANSIENT Analysis across a certain component?!
Hey guys, I am trying to figure out how to do a transient analysis across a certain component.
For example, I have a resistor between the 12v source and the collector of a transistor, and I want to analyze the voltage across the resistor alone.  But under the parameter setup in Transient Analysis, it will only allow me to select that segment with reference to ground.  I don't want to use the ground reference.
Thanks.
(3,503 Views)
I think I may have answered my own question.  I am able to use an expression to subtract the two voltage reference points, so I guess that's as good as I need.
(3,496 Views)
I know you are using the Analysis tools under the simulate menu, but you could have possibly just put the Multimeter across the resistor to see the voltage across it. This would not work if you need to print the results.
I thought I would just pass this along. You probably already knew this anyway.
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(3,483 Views)
