Multisim and Ultiboard
Editing multiple items in spreadsheet
I am an Ultiboard 12.0.1 user and trying to edit the spreadsheet of a design transferred from Multisim.
I want to SIMULTANEOUSLY change the width and spacing of multiple (more than 200) traces to the same values,
because I have found that even editing one trace at a time takes about 20 seconds.
I am doing this on the spreadsheet instead of modifying the "Design Rules Tab" in the "PCB Property Dialog"
because I have found that the latter takes NO effect on the worksheet.
Is it possible to do the simultaneous editing of multiple items above?
If yes, could anyone tell me how to do it?
Thank you in advance.
Akira
(4,632 Views)
In your nets spreadsheet in Ultiboard, just push the CTRL key and select all the nets you need
or combine SHIFT and CTRL to make your selections as you would do in another windows environment.
Succes!
stressed user
(4,572 Views)
