Multisim and Ultiboard
Electrical schematics with NI instruments
Hello All,
I am trying to draw a schematic for the following system: NI PXIe 1071 Chassis with NI PXIe 8115 Embedded Controller, NI PXIe 6363 DAQ and some sensors (Temposonics, load cells and pressure sensors) with their individual power supplies. What are some of the software options to draw a such a schematic? Is there some software available which has these NI instruments built-in? Thank you.
(721 Views)
why are connections analyzed inside the block? how can I draw a normal smd antenna so that it doesn't merge with the polygon?
(682 Views)
