Multisim and Ultiboard
Error: An unexpected Licesning Error
I have just downloaded the Evaluation version for Multisim 10.0. I have lnstalled it but when I open the file it says "An unexpected Licesning Error". Please help.
Roman
(3,815 Views)
You may have a missing license file. Follow this link and download the appropriate license file: http://joule.ni.com/nidu/cds/fn/p/sn/n23:4.6863/lang/en
After downloading the file select from the START  button All Programs>National Instruments>NI License Manager. Once inside Lincense Manager select Otions>Install License File. Navigate to where you stored the file and select it, Follow any addition instructions from that point to activate it.
I hope this helps. Have a Nice Day.
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(3,806 Views)
Roman,
This is generated when the license files are not properly installed or they have been deleted. You can try to repair the installation and/or re-install the software from the original CD, or if you downloaded the evaluation, make sure you have unzip the files in your local disk (C:).
Individual license files should be installed when you repair, on any case, you can find the specific license to use depending on the Edition you have in here:
ftp://ftp.ni.com/support/circuitdesignsuite/licenses/10.0
And they should go in here:
C:\Program Files\National Instruments\Shared\License Manager\Licenses
Nestor
(3,766 Views)
