Multisim and Ultiboard
Error during netlist generation and log audit trail error
I am not able to run the simulation application on my Multisim 10.  The two following error were generated every time I try to run the simultion:
Error: log /Audit Trail, C: \document~1\xxx: Permission denied
Error during netlist generation, C:\document~1\xxx: Permision denied
Can any body help me fix this problem that make it impossible for me to use the Multisim10 simualtion tool?
(5,907 Views)
There are two KBs I would like for you to see, since they might have the answer to the problem you are having:
1. This KB is related to having access to the TEMP directories where Multisim stores temp files for simulation:
http://digital.ni.com/public.nsf/allkb/15526EB2464F3EDD8625722C00696BB0
2. This other KB deals with non-Administrator users of Windows, it talks about v9 but the idea is the same for v10, just look for the v10 installation paths:
http://digital.ni.com/public.nsf/allkb/0DF597C217A235BE862571FB004F24BD
Nestor
(5,899 Views)
Thanks Nestor, one of the links you sent has the solution to my problem.
Everything is running fine now.
(5,885 Views)
