Multisim and Ultiboard
Error merging user database
When I try to merge a database, I get the following log, and no parts imported
Database Merge
Date: October 26, 2009 11:07:11
Overwrite Type:Auto Rename
Processing databases:
C:\Documents and Settings\t010-1\Desktop\Usrcomp_S.usr ==>
 ==> C:\Documents and Settings\t010-1\Application Data\National Instruments\Circuit Design Suite\10.0\database\UsrComp_S_t010-1.usr
Processing table:[SYS_CONFIGURATION_GROUPS][OK]
Processing table:[SYS_CONFIGURATION][OK]
Processing table:[SYS_HISTORY][OK]
Processing table:[SYS_TECHNOLOGY][OK]
Processing table:[SYS_EDA_SYMBOL_MAPPING][OK]
Processing table:[SYS_COPYRIGHTS][OK]
Processing table:[SYS_USER_TITLES][OK]
Processing table:[SYS_MODEL_PIN][OK]
Processing table:[SYS_PCB_PACKAGE_ORCAD_TO_MSM][OK]
Processing table:[SYS_PCB_PACKAGE][OK]
--- Total number of component(s) = [0],
    [0] component(s) converted,
    [0] component(s) ignored.
Processing table:[SYS_COMPONENT][OK]
Processing table:[SYS_MAPPING_VIRTUAL_COMP_PACKAGE][OK]
No current record.
Error Code: 3021
Processing table:[SYS_SPECIAL_VIRTUAL_COMPONENT][Error]
Processing table:[tUserTree][OK]
--- Total number of objec(s) = [0],
    [0] object(s) converted,
    [0] object(s) ignored.
Processing table:[tObjects][OK]
Done
(3,575 Views)
Maybe your database was created in V9 or earlier, try selecting Tools>>Database>>Convert instead.  If you still have a problem, can you post yout user db on this forum?
Tien P.
(3,555 Views)
