Multisim and Ultiboard
Error writing to file during Multisim installation
Hi, I am getting the following error:
An error occurred while installing a package: ni-cvi-2019-reflector (19.0.0.49152-0+f0)
Additional error information:
An error occurred while installing the MSI at 'CVI_Reflector64.msi'. Error writing to file: NationalInstruments.CVI.Reflector.dll. Verify that you have access to that directory.
I made sure I had permissions to change the folder containing that file. I turned off the firewall and virus protection. I don't have any previous NI software installed. Totally stumped. Running Windows 11 via Parallels on a M1 Macbook.
(1,957 Views)
Привет, Мика!
Не советую устанавливать MS на версии старше 7
В Windows-10, MS14.2.0 считает ее в 2 раза медленнее, чем в W-7, а в W-11 вообще глючит, кажется, туда надо добавить старые библиотеки оболочки (Фреймворк ...)
(1,922 Views)
Windows 11 does seem to be buggy but it finally worked. Just had to completely isolate the virtual windows machine from the Mac side and disable access to any folders, as well as do an offline install. That worked.
(1,879 Views)
currrently running into the same error with labview, Trying the same offline download along with looking into firewall settings.
(1,822 Views)
