Multisim and Ultiboard
Evaluation copy
Designed a known working 555 timer circuit but can not test.  Dose the evaluation copy prohibit this
(3,237 Views)
The only limitation with the evaluation version is that you can't print, you should be able to simulate.  Did you connect scope to the circuit?  On the main menu select Simulate>>Instruments>>Scope
Tien P.
(3,234 Views)
