Multisim and Ultiboard
FET body effect
Hi all,
I need help to simulate the body effect on a FET.
If I use a Virtual FET, such as MOS_4TEN_VIRTUAL, where can I edit the body effect (gmb)?
What is the specific parameter?
I appreciate any assistance.
(4,393 Views)
Hello Tonitos,
Mutlisim is especially suitable for circuit simulation. You can edit templates with the "Model Maker":
 - Start the "Component Wizard by going to Tools Component Wizard
The equation editor for mathematics as the "body effect" is much lower level.
Also, you can edit a model with SPICE (*. cir) and import it into Multisim.
Attached:
- SPICE.PDF (FET modelisation)
- Multisim.jpg (model Maker)
(4,339 Views)
Un esquema del transistor FET
(3,467 Views)
