Multisim and Ultiboard
FM RECEIVER CIRCUIT FOR BATTERY SUPPLY
Hi..
i have project (radio sc1088)for simulation ...and i don't have this component in multisim so i wanna 2 make it with footproint(sop-16) according 2 data sheet but the problem in model maker i don't know how to make it the simulation part?
hope that u can help me ...
thanks
(5,880 Views)
I am not sure if you are needing this for simulation purpose or just layout purposes. If you are needing this to simulate then I really think that would be extremely difficult as there is probably no spice models for it and creating one would be a nightmare to say the least.
If you just need the package outline/symbol then that would be much easier to do. Just create a new component without a model with the number of pins you need then label those pins to what the datasheet calls them, select your footprint you want assigned to it and then save it to the user database. There are tutorials on the NI site that can be very helpful in doing this procedure. It is way to lengthy for me to outline here on the forum and I don't have a link to it. You can do a search for "Creating Custom Components in Multisim" and you should find it.
If I totally misunderstood what you need, let me know and I will see what can be done.
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(5,840 Views)
thanks for ur reply ...i wish that i have ur knowledge
i made the layout (exactly the same as the real one according to datasheet which its sop-16 footprint)
the problem is the simulation part ,,,i know its very difficult
help me with any fm receiver chip (like sc1088 ),,,
thanks again ,,,sorry 2 bother you
Message Edited by 00962 on 05-17-2008 09:51 AM
(5,838 Views)
