03-10-2013 11:26 AM
I am planning to use the Hirose FX2-100S-1.27DS connector in my design. Unfortunately, there are only 3 connectors by Hirose in the software and none of them is the one I want to use.
Is there another model with the same dimensions that I can use? Or do I have to create my own model?
This is a link to the data sheet of the part: http://www.hirose.co.jp/cataloge_hp/e57220088.pdf. If you search for the part number (FX2-100S-1.27DS) It should provide you with the dimensions of the part
Thank you in advance.
03-12-2013
03:07 PM
- last edited on
08-09-2024
11:08 AM
by
Content Cleaner
Hi Mohd_Ali,
I couldn't find anything comparable in the database so unfortunately, you will have to create your own.
Here is a tutorial on how to create footprints in Ultiboard.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YH7qCAG&l=en-US
Hope this helps.
