Multisim and Ultiboard
Footprints/Dimensions
Hey there guys,
I'm seeking some help for finding the proper dimensions and footprints when transferring from Multisim to Ultiboard, I'm having a really tough time finding the proper manufacturers to match the required footprints and dimensions that I need...
These are the measurements that I'm struggling with...
Resistors :                Footprints:10.16mm     Dimension : 6mm x 3mm
2.2 uF Capacitors : Footprints: 5.08mm       Dimension : 7mm dia x 12mm height
10 uF Capacitors  : Footprints: 7.62mm      Dimension :  6mm dia x 3mm height
Those measurements will be evaluated if they're matching their requirement hence why I need to have them approximately.
I've got this circuit due for in a couple of days and I am completely stuck there so any help would be greatly appreciated!
(2,438 Views)
AxisSe7en have you tried making your own footprints for the devices?
You can also look for DXF files that match your requirements.
(2,400 Views)
