Multisim and Ultiboard
Footprints in Multisim 13.0
I custom made a footprint in Ultiboard for a DC source in Multisim 13.0. However, I am not able to edit/add a footprint to the DC source.
Right now what I am trying to do is edit Footprint under Spreadsheet View.
Any suggestions would be greatly appreciated!
(4,535 Views)
Hi Marissa4424
If you have exported the footprint from ultiboard to the database, you should be able to select it from the database from the "Edit Footprint" window that you mention. Here is a document that explains how to open that same window from another location in Multisim and also how to select the footprint from the database.
If you cannot see your footprint from the Multisim environment, please read this document and let us know if it helps!
Cheers!
WenR
(4,495 Views)
Hey Marissa4424
I hope you are doing all right! After posting my previous response, I was informed that, from the description you have given, what you are seeing is a bug that was found un Multisim 13.0 and fixed for the 14.0 version of the software. Sorry for the confusion!
WenR
(4,426 Views)
