Multisim and Ultiboard
Fourier Analysis
Hi there,
I have problem with my simulated 3-phase inverter to do fourier analysis. I have a square wave switching inverter and the load is a simple resistor network (star). I use the fourier analysis from simulate menu but at the end of process it says lengths dont match 1705.the fundamental frequency is 400Hz and time start is zero, the Tstop is 1 sec, span and end frequency are 6KHz, Tmax is 2e-5 and number of harmonics are 20.
Thank you for your time
(3,210 Views)
Please attach your design file and I will take a look at it and try to help you with the fourier analysis.
Mahmoud W
(3,202 Views)
