Multisim and Ultiboard
Full-wave rectifier circuit from AD8512 datasheet do not work
Help me please!
Simple circuit from AD8512 datasheet p.16 do not work. May be AD8512 model is bad?
(3,539 Views)
Hi Zauberer,
I suspect it's the problem with the spice model. When I used another opamp with the same circuit it worked fine. Unfortunately there's nothing we can do right now. We couldn't update the model from the manufacturer becasue it was the latest version. What you can do is to contact Analog Devices to report this problem. Or you can simply replace the opamps with some similar ones and see if it works. Just FYI, the model I used was OPA342NA. Hope this helps.
Derek Z.
(3,521 Views)
Thank you, Derek!
(3,513 Views)
