Multisim and Ultiboard
GATE FAN IN AND FAN OUT NOT DETECTED IN MULTISIM PROGRAM
GATE FAN IN AND FAN OUT NOT DETECTED IN MULTISIM PROGRAM..
TO MANY GATE INPUTS TIED TO ONE GATE OUTPUT ISN'T DETECTED..
GATE OUTPUT CAN ONLY HANDLE 16MA.
EACH GATE INPUT DRAWS 1.6MA.
NUMBER OF GATE INPUTS SHOULD ADD UP ABOUT 10MA.
THAT EQUALS ABOUT 5 TO 6 INPUTS PER OUTPUT.
RICHARD RUHL
Message 1 of 10
(7,436 Views)
Hi Richard,
Do you have a circuit to illustrate what this?
Tien P.
Message 2 of 10
(7,414 Views)
pattern16t file I gave you a month ago
richard
Message 3 of 10
(7,397 Views)
pattern16t file I sent you a month or two ago
richard
Message 4 of 10
(7,395 Views)
I changed the circuit  by adding additional gates to work with the real chips.
this is ware the problem would show up with burnt up chips.
attached is the corrections to keep this from happening.
Message 5 of 10
(7,390 Views)
came upon another problem if there is a problem.  the displays on my circuit flash 6A twice then there is a gap befote the displays flach 6A twice again.
Is this gap the time the sinulation rngine of multisim takes to calculate the sinulation results.
if you put pattern16C under pattern16D you will see thee whole design and funtion of my circuit.
Do you think my circuit is worth anything and how much do you think my circuit would be worth.
richard ruhl
Message 6 of 10
(7,341 Views)
do you have a bit map of a 40 pin scsi controller chip.  I need the data sheet to make a symbol in multisim program.
rich ruhl
Message 7 of 10
(7,322 Views)
I looked at you "Pattern16C" and "Pattern16" file but I don't know where the problem is, please provide more details.  I don't see component or net called "gate fan it" or "fan out", where should I look?
I don't have any information on a 40 pin SCSI controller, you should look for the datasheet from the manufacturer website.
Tien P.
Message 8 of 10
(7,299 Views)
the voltage should drop on the output of the chip connected to to many inputs and should showw an error from the  the simulation engine of the software automatically   what it does is over load the circuit amp wise.
richard ruhl
Message 9 of 10
(7,252 Views)
Hi Richard,
The model for digital components in Multisim have behavioral model, that is, the input or output is either high or low. Regardless how many inputs or outputs you have, if the circuit logic is high you will read VCC and when the logic is low, you will read ground.
Tien P.
Message 10 of 10
(7,232 Views)
