Multisim and Ultiboard
Gain Issue After Choosing Package for Capacitors and Resistors in Multisim Simulation
I designed a circuit in Multisim, and everything was working fine initially. However, after selecting the appropriate packages for components (resistors and capacitors), I noticed that the gain dropped significantly, and the circuit's performance became inaccurate. The components are all in 0805 package with tolerances of 1% for resistors and C0G for capacitors, but the result is still incorrect at around 1 MHz frequency.
Has anyone encountered a similar issue with Multisim simulations after changing component packages? What might be the cause, and how can I resolve it to maintain the desired gain and circuit accuracy?
Thank you for your help
Message 1 of 1
(330 Views)
