Multisim and Ultiboard
Get error 998 when starting Multisim 10 on Windows Vista Home Basic PC (Ultiboard too)
I´m getting 2 errors when I start Multisim and Ultiboard, which are:
Error loading library C:\Program Files\National Instruments\Circuit Design Suite 10.0\Autoroute.dll, ('998')
The data area passed to a system call is too small.
AND
Error loading library C:\Program Files\National Instruments\Circuit Design Suite 10.0\DDFlink.dll, ('998')
Invalid access to memory location.
and after that it freezes, does anyone know what to do?
I´ve already tried running it as an administrator, and in Windows XP compatability mode...
Thanks for any help,
John
(4,221 Views)
Hi Yetti!
Unfortunately at the moment Multisim 10 is not supported under Windows Vista. There should be a patch very shortly for it. One recommendation i can make is that you uninstall the circuit design and that at reinstalling you dont allow the SSU to install any update. I can't guarantee this will work but it may fix a few things for you.
Best Regards!
Oswald Branford
(4,212 Views)
Hi Oswald,
Thanks for the info, I will be waiting for the patch.
John
(4,209 Views)
