Multisim and Ultiboard
Grouping subcircuit components
When dealing with multi-channel boards it is very sleak to group every channel in multisim and have that information forwarded to ultiboard. If you however have these channels in subcircuits/hierarchial blocks the grouping doesn't work, it assumes that all subcircuits of the same type belong to the same group, which is exactly what it normally doesn't when designing several channels.
I've been using the tools frequently recently and am wondering where to submit bugs. There are several things I've come across as well as faulty footprints in the supplied component database. Where do I submit this?
____________
/Peter Hygren
(3,300 Views)
Hi Peter:
I will add your feature request. It seems like a great idea!
You can always submit bug through the Contact NI link at the bottom of every page. Then click Request Support (under Technical Support), and select Email NI. You can always submit bugs, even if you don't have a valid service contract. And please do let us know!
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(3,267 Views)
