05-19-2016 04:26 AM
05-20-2016
03:25 PM
- last edited on
10-17-2025
09:08 PM
by
Content Cleaner
Hi SegotsoKatie,
I believe that the conection of the PIC16F877 will depend on what you are going to do with it and what pins you will use at the end, I can't think on a typicall conection because it is very modular. FYI take a look at the following document maybe can help you on your way to use the PIC16F877. Thank you.
http://www.ni.com/tutorial/52653/en/
Also if you go to Help>>Find Examples you will find more ideas. Hope this helps
Luis G.
NI
