Multisim and Ultiboard
HOW TO USE MORE INPUTS AND LESS GATES
Im doing reviewing homework and I have always had this problem. ill put in a truth table and I tell it to make an And or circuit but i think it uses more gates than necessary. when i simple 4 input and could be used it breaks it down to 4 seperate and gates. Is here a setting a can change for this.
EX: A'BC'D+ABCD
(3,273 Views)
I assume you are using the logic converter. It is not possible to edit the number of gates the logic converter will use. It will generally design the circuit in the easiest possible configuration. It gives you an idea of how to design the circuit.
Hope this helps.
Tayyab R,
National Instruments.
(2,906 Views)
