Multisim and Ultiboard
Help, Ultiboard has slowed to a choppy crawl.
Today when opening a previously created file, Ultiboard had reconfigured itself with new toolbars and various other options. Now Ultiboard has slowed to a choppy crawl, making it impossible to work with efficiently. The version is 10.0.267. Please Help.
(4,264 Views)
Update. I had originally suspected an update to be the problem, that does not appear to be the case.
I create a new file every day and have been able to track it back to a day I added a top layer ground plane and then removed it. Even with it removed the file remains slow to react.
Has anyone else encountered anything similar?
(4,250 Views)
Try making a select all, then copy / paste everything on a new file. It might be possible that the file has something corrupted inside. Maybe a new file could help...
Nestor
(4,248 Views)
Thanks Nestor!
I am running a normal speed againSmiley Very Happy
(4,245 Views)
