10-31-2008 11:06 PM
I need help with my project.
I'm new in the subject of electronics so i really don't know much of the terminology
I also tried making the circuit using multisim, but i was not able succeed in making the 12.5V DC output
i was able to make the rectified output but until there only and most of the time i get an error.
I know some items to be used like diodes and transformer the problems are that i dont know
what to select from the transformers and diodes and resistors and capacitors.
I saw some cicuits but i really dont know what they are e.g. [the huge triangle (not the inverter for logic circuits/TTL)]
as much as possible i want to make a circuit that is made of the lecture scope of our electronic
these are diodes, transistors[not yet discussed]
i know but minimal knowledge of some components these are capacitors, transformers, resistors
is it possible to make a AC-DC supply w/o transistor?
I want to ask for help of somebody to help me make a circuit diagram in multisim.
i'm asking nicely if anyone can help me.
please dont flame me T_T.
thank you for reading and replying
11-01-2008 06:03 PM
O.K. This is not a flame as you call it, but we here at the foum frown on students wanting us to do their work for them. It is not ethical nor is it fair to you as you would not learn anthing by us doing that. A nudge in the right direction though is acceptible.
Ylu say you are familiar with transformers, diodes, and resistors. This is your answer. You just have to figure out how to put those elements together.
Sorry, but that is all I am going to say. Don't think of me as being cruel as that is not my intention. I just want you to learn how to figure thing out a little on your own. That is the best way to absorb knowledge.
11-01-2008 09:36 PM
i was able to make a DC of 26V how ever i cant bring it down to 12.5V any tips or instructions?
i trying virtual parts
11-01-2008 09:43 PM
I will give you a hint. Think about the turns ratio of your transformer. Here in the U.S. 120V to 12V would be a 10:1 ratio.
I am sure from this you should be able to get the rest.
11-02-2008 01:13 AM
i some some ripple a very small ripple can this cause problems?
11-02-2008 06:12 AM
i need comments on my work. any comments or mistakes you see and please advice me what should i do next
please tell me is the very small ripples i see is normal.
this is going to be my project for electronics in breadboar and in PCB
11-02-2008 08:14 AM
