Multisim and Ultiboard
Hiding Component Name in Multisim
Hi all,
I'm drawing up some schematics using Multisim 14 and am looking for a way to hide the component names that are automatically placed next to said components. In these cases, the component names are typically just a string of numbers that are not important for the schematics. Is there a way to hide them without completely deleting or changing the name in the database? As seen in the attached picture, I am using other labels that are included, but if the only way to hide the component name is to hide the whole title block, then I can easily just add a separate text block.
Using the image as an example - what is there is what I currently have and I am trying get rid of the "1581," which is the component name in the database.
Any help would be greatly appreciated, thanks!
(11,834 Views)
Accepted by topic author saundeep
Hello..
your problem is solved simply. ..  the right mouse button on the object-choose properties-display and further relieve the "birdies.".
(11,814 Views)
Didn't realize it was that simple....thanks for the help!
(11,806 Views)
