Multisim and Ultiboard
How I can Find any Dual-Output (Positive and Negative), DC-DC Converter ( MAX685)
I need to know if there is any DC -DC Converter in the multisim library  , as the MAX685
(3,451 Views)
Hi MMMD,
thanks for contacting us.
Unfortunately this part is not available in Multisim, actually we do not have DC-DC converters in the database. We also tried to locate a SPICE model for the MAX685 in order to create a custom part, but the manufacturer has not created any models for simulation.
Please contact the manufacturer directly to see if they have a model available.
If you need the component only for schematic capture and layout, you can create the part in the Component Wizard using the datasheet.
Let me know if you have further questions.
With best regards,
Ralf N.
(3,428 Views)
