Multisim and Ultiboard
How best to simulate a small tuned amplifier in multisim 12
Hi
I wonder if some one could help with regards to the simulation of my tuned amplifier circuit , I am unsure of how to get the best simulation and waveform for the circuit , I know how the ideal should be but I can not seen to get the ideal or anywhere near ,I have experimented with certain analysis and still seem not to get quite near can some one explain what I am doing wrong.
        gringo
(6,738 Views)
Hi Gringo8217,
Thanks for posting on the forums.
I wanted to find out some more information from you regarding this Multisim simulation.
- Exactly what type of waveform are you expecting? What values are you trying to get?
From looking at your circuit design it looks like there is a resistor missing (R1 considering the below image). Take a look at the following diagram of a tuned amplifier and compare your design. It may be of help.
Tuned Amplifier Circuit
If you could provide more information, I will then be able to help you further.
Kind Regards,
Dom C
(6,709 Views)
Hi
Thanks for the reply ,the amplifier is given to me too simulate the circuit the missing R1 as you suggested is not to be used , i am un sure on the output and the best way ti simulate can you advise ?.I have simulated but unsure on the output if it is correct or not .
        gringo 8217
(6,681 Views)
If R1 is missing from the circuit which Dominic C. posted, then the circuit is probably operating in Class C. That means that the transistor only conducts during a small portion of the input cycle when the instantaneous signal voltage is larger than 0.7 V.  Class C is used for power amplifiers because it can be quite efficient.  It relies on the Q of the tank circuit to store energy and generate a (nearly) sinusoidal signal at the output.  If the Q is too low, harmonics and reduced efficiency may occur.
Try driving it with an input signal of at least 1 volt peak.
Lynn
(6,674 Views)
