Multisim and Ultiboard
How do I add a copper layer?
I exported a circuit from Multisim to Ultiboard.  I want it to be a two layer board, but the copper top layer is missing from the design.  The last board design I made using Ultiboard was a single layer and the problems seem to stem from that.  Anyone run into this problem before?  Also, why can't we easily add or subtract layers we do or don't want in our design?
(4,776 Views)
I tried to re-create your scenario by creating a new project in Ultiboard that was single sided only. I then saved the file I created, closed that file and then went straight to Multisim and exported a circuit to it. My exported circuit came up as a double-sided board even though I had just done a sigle sided project (very small as it was).
I couldn't recreate, sorry
Message Edited by lacy on 11-13-2007 06:13 PM
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(4,770 Views)
I am not sure which version of Ultiboard that you have, but in the Power Pro Edition you can use the spreadsheet and just delete any layer you want that is listed there.
I have not found any other method of doing this. What I usually do is to use Ultiboard set up for double sided boards and if I want to use just one layer I make all other layer unroutable. You can do this under OPTIONS>PCB PROPERTIES.
I don't know if this is of any help to you but is all I could find.
Have a Nice Day
(4,766 Views)
I have an idea for you to try. If you already have your file exported to Ultiboard you can try to delete the board outline and run the board wizard. This will allow you to change the technology and make the copper top come back. Just choose double sided board within the wizard and hopefully this will restore the copper top layer for you.
This is the only method I could find that would help you. This may not be the only way to do this, but this seem to be the simplest method I could find.
You might be able to use this method for removing layers that you do not want. Multisim always exports as a double sided board so if you do not want a double sided board after export you could use this method to remove the copper top. Just an addition thought that may help.
Message Edited by lacy on 11-13-2007 06:42 PM
Have a Nice Day
(4,764 Views)
Thanks for the help.  Your last idea about deleting the board outline and then using the board wizard worked.  Thank you again.  I thought loading in a new user config would have reset the defaults but that didn't work either.  Looks like we've found another slight bug.
(4,752 Views)
lacy contact me via email when you get this message. thanks
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
(4,737 Views)
