Multisim and Ultiboard
How do I add components to Multisim 8. I need to amplify a 900 MHz signal.
Hi, I am trying to amplify a 900MHz signal with multisim 8.
I have done some searches and I have not found any transistors or op-amps that will amplify this high frequency on multisim 8.
I have found 2 different Low Noise Amplifiers (LNA) on the net that could work.
I found a BFG480W and STB7001.
I have heard you can import new devices to your library.
Does anyone have these files and know how to add them in?
I looked and I do not see a "Library" folder.
(6,192 Views)
In Multisim you can use the Component Wizard (Tools>>Component Wizard) to create a custom component. Here is a tutorial on how to use it:
Creating a Custom Component in NI Multisim
Fernando D.
(6,141 Views)
