Multisim and Ultiboard
How do I connect hole pads to ground studs on a board?
I struggled with this issue.  Also, noticed nobody had publish a good solution, so I am sharing my solution to the community.  It is good practice to use a 4 layer board design and assign Inner Copper Layer 1 as a ground plate.  There are multiple tutorials on the layer part, so I will only show the hole pad connectivity part.
This will be done through screen shot/shots.
Thanks.
-Sergio
Test Engineer
Message 1 of 1
(953 Views)
