Multisim and Ultiboard
How do I create a void in a power plane?
Yes, and I found a side effect of the trace and remove island.  If you try to move the area by moving the trace, you can end up removing the whole power plane apart from stuff INSIDE the trace :-).   Not sure if this is a bug or not, but I ended up using a keep-out as described above.
Thanks Dave
Message 11 of 14
(1,725 Views)
That's interesting, and sounds like something that shouldn't be. 🙂
____
Ryan R.
R&D
Message 12 of 14
(1,717 Views)
You've definitely identified something interesting here. The void is just getting bigger, and I can easily imagine this is what you would want. I'll enter this into our defect tracking tool.
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
Message 13 of 14
(1,700 Views)
just use the copper area spliter,
Message 14 of 14
(652 Views)
