Multisim and Ultiboard
How do I fix my Triac based control circuit used for induction motor speed control?
Curcuit DiagramCurcuit Diagram
Incorrect OutputIncorrect Output
Correct OutputCorrect Output
Hi guys, so I have designed a speed control circuit for an induction motor. The circuit consists of a zero cross detector circuit whose output pulse is the input to a 555 timer. The 555 timer is used to generate a PWM wave that is then inputted into an optocoupler. The TRIAC control circuit then applies a chopped AC waveform to the induction motor. The 1st picture is the circuit diagram.The 2nd picture is the chopped waveform (incorrect) applied to the motor (used a lamp in multisim as there is no motor), the 3rd picture is how the chopped waveform should look. I am having trouble (with the negative half cycle) with getting the waveform in the 2nd picture to look like the correct waveform in the 3rd picture. I suspect that the problem is the MCT6 optoisolator, but I am unsure about which component to use instead of that. Can you guys please help fix the design?
(2,569 Views)
Look at U6 on the negative part of the AC the opto-coupler Collector pin will be negative compared to the Emitter pin. Try an opto-coupler with a diac output instead.
(2,486 Views)
Хай!
Если тема актуальна, скиньте файл "ms"
Я тоже интересуюсь симисторами.
(2,348 Views)
