Multisim and Ultiboard
How do I make generic spice models work in multisim?
Dear Mr.Garret,
Thanks for the post.It was informative.
I need your advice and help on the following.
I have a small subcircuit as shown below.
The diode D1 parameters are as given below
+  IS=2.8e-009 N=44 RS=0.003866 BV=1e+030 IBV=0.001
In need make a component out of it.
When I followed NI tutorials and put the Pos and Neg pins on to the terminals and made  a component,
Instead of giving a diode like IV curve,the DC sweep analysis is giving a Resistor like IV curve.
The above circuit works fine if Vdd is put at Pos and Gnd is put at Neg and then apply DC sweep.
Please help me make a component which should work the same way as the above circuit.
I think I am going wrong somewhere which I cannot comprehend by myself.
boby.
Message 11 of 13
(2,029 Views)
can someone answer and help please!!:manmad:
Message 12 of 13
(1,983 Views)
Hi Bob,
To create a model from your circuit do this:
1.  Double click on the diode and make sure it have all the SPICE parameter that you want
2.  From the menu, select Transfer>>export netlist, Multisim will create a .cir file
3.  Open the .cir file with Notepad
4.  On the first line add this:  .subkct model pos neg
5.  scroll to the bottom and type this:  .ends
6.   In Notepad do a Edit>>Select all and then Edit>>Copy
7.   In Multisim go through the component wizard to create the component. Here is the link to the component creation tutorial
http://zone.ni.com/devzone/cda/tut/p/id/3173
8.  In the tutorial, when you get to Step 6, paste the model into the "model data' area
Tien P.
Message 13 of 13
(1,974 Views)
