Multisim and Ultiboard
How do I show multi-voltages in Multisim?
I am trying to place +12v, -12v and +5v voltages in my schematic to power IC's.
What symbol do I use? VCC is no good, cannot use more than one voltage applied to it. Change one, all change. Test_pt is no good, same reason. Is there a universal symbol that does not have to be used in simulation for voltages?
We do not simulate most of our boards. They are re-builds of old military equipment. Most of the parts are not even in production anymore.
Thanks for the help.
scotty544
(4,784 Views)
Sorry, but I do it the simple-stupid way:
---- +12 -----
----  -12 -----
---- +5 -----
Tie analog ground (GND) between the + 12 and -12 supplies like so:
(-12) ----- +12 ---- GND ---- +12 ---- (+12)
Then connect the IC as necessary (using the (-12) and (+12) ends) via traces.  Yes, I know it can be a mess of traces, but I'd rather know what I have than guess how Multisim interpretted things for me.
Then, of course, tie your +5 supply to the ground.  Now every supply is referenced to ground.
If there is an easier way, it sure hasn't become clear to me.
(4,776 Views)
Just change the refdes of the Vcc supply connection and then it will be treated as a different supply.
i.e.   5V, n5V (for -5V ), 12V, Vref, or whatever.
You can set the voltage of each independently for simulations.   Each separately named supply is treated as a single net.
Just what you want.
David B
(4,721 Views)
You'll get a warning about changing the supply name when you do it.  I think the only problem you might have is if you have components with invisible supply connections you may not end up with them connected correctly if you are not careful.
I always use explicit supply connections to avoid any confusion.
(4,718 Views)
