Multisim and Ultiboard
How do i place a teardrop between two crossing traces?
Hi.
I'm new at this forum and a beginner, so don't be surprised by my questions. Smiley Happy
I have couple of crossing traces and i like to add teardrops to make it nicer and efficient.
Also i like to know how can i clean traces edges. The ones that appear when you tracing with 20 thou and then continuing with 10 thou.
Thank you.
(3,166 Views)
Hi Smoovo,
Teardrops are used to strengthen the connection between the trace and a pin. If you want to add some more copper where your traces are intersecting, just go to Place -> Line and then add copper where you need on the board.
I am not exactly sure what you mean by cleaning up trace edges. It is not really possible to delete or erase part of the edge of the trace. You can move it around by grabbing it and dragging it until it looks the way you want it to look.
Hope this helps.
Tayyab R,
National Instruments.
(3,156 Views)
