Multisim and Ultiboard
How to Import Components afterwards from Multisim to Ultiboard ??
I added a component to my schematic in Multisim and when I change to Ultiboard the Component is not imported into.
How can I import the new component without making a new Ultiboard-File ??
Thanks in advance
(3,222 Views)
You can choose to Forward-annotate your circuit to Ultiboard. You can find the option under Transfer. That way you can import your newly added components in to your layout design. Please be noted that the models without footprints will not be successfully imported because they are not meant for being used in the PCB design. Hope this helps,
Cheers,
Derek Z.
(3,214 Views)
