Multisim and Ultiboard
How to add current transformer library to components
 I am working on 3-phase power supply project.but i didn't get current transformer from Multi sim 14.2 components. Could you help me how I can add  current transformer to the Multi sim?
(2,752 Views)
Hi firish,
I am not sure if you would be able to configure a current transformer as a component with Multisim, as it might not be able to simulate the magnetic filed of the coil. However, depending on what you're trying to do, where are two components you can use: a current-controlled current source, which can be found in Sources group under the Controlled Current Sources family or current-controlled voltage source, which can be found in Sources group under the Controlled Voltage Sources family. You can use current-controlled current source, if you want to have a current at the output. The current gain of this component would be the turn ratio of the transformer. In case you want to get voltage at the output, use current-controlled voltage source. This time the transresistance of the component would be your turn ratio. Here is an example how you can use the current-controlled voltage source:
You can read more about these components here.
In case you do want to try to add it as a component, this article will be helpful.
(2,710 Views)
