Multisim and Ultiboard
How to change efficiency of BUCK_CONVERTER?
I am trying to simulate a buck converter with a worst case efficiency of 80%.  I am using the built-in BUCK_CONVERTER that is in the Misc family.  It is working great, but its efficiency is 100%.
Can someone help me out?  Is it possible to change the efficiency of this part?
(3,936 Views)
I should have mentioned that I am using NI Multisim 13.0 (Power Pro Edition).
(3,935 Views)
Hello chevymanar
Basically it is not possible to change internally something that can variate the efficiency of this component however I was thinking that you can try to change the L, R and FS in the value tab.
That is the cost of simulate components something those work better than components in the reality.
Regards
(3,916 Views)
Hi chevymanar,how to use built in buck_converter
(2,614 Views)
