Multisim and Ultiboard
How to connect a BJT circuit in multisim
see attached for the diagram with most the info, the addition info are using a 2n3904 NPN transistor and a 20mVpeak 2KHz ac supply.
(3,757 Views)
Hello Joeyy,
I do not understand your issue. Do you just need help to build a schematic in Multisim based on that diagram?
If you are starting with Multisim this document has very good resources.
Basically, you have to create a new design, in the schematic area right-click and select Place component. This prompts the components database, select the component and press OK.
Jose F.
(3,699 Views)
yes, i really need help to build the circuit and test the output via oscilloscope and voltages and currents in the circuit.
(3,693 Views)
