Multisim and Ultiboard
How to connect using 7447N to 7 segment display?
7-SEGMENT DISPLAY EXAMPLE WITH CODE using pic18f4520 MPLAB IDE
Hope this will help you.......
http://pic18forstudents.co.uk/
Message 11 of 24
(3,926 Views)
try this ckt
Ed
Message 12 of 24
(3,685 Views)
hi i am new to NI
i dont understand why my 7-segment display light uo even though i power supply is provided,
pls dont change basic gates circuitry
thks
Message 13 of 24
(3,621 Views)
You need a command anode (CA) display since the common is connected to VCC. Using a common cathode (CK) basically reverse biases the LEDs so they won't light.
Message 14 of 24
(3,614 Views)
That is correct.
Replac3e the common cathode (CK) with a coommon anode (CA) display.
Ed
Message 15 of 24
(3,606 Views)
hi,
i tried replacing but did not light up.and got simulatiion error and i sther any way stick using common cathode display as it is the requirement of the system and the digital circuitry is such that it matches the 7 segment common cathode display.
thks a lot
Message 16 of 24
(3,592 Views)
`how to remain using common cathode 7 seven segment display
Message 17 of 24
(3,588 Views)
I changed the analog groung to digital ground, and i added a Common Anode 7 segment display.
The display now works.
What is the logic circuit supposed to do?
What are the 3 switches supposed to control?
Check your logic and your wiring.
Ed
Message 18 of 24
(3,587 Views)
Try this one
Ed
Message 19 of 24
(3,584 Views)
Here is your ckt with a CK display.
If any segments flicker while simulating, STOP the simulation and then START it again.
The circuit still puzzles me. The output display still look like nonsense. Min 0 generates a 6; min 1 generates an upper case E.
Very strange outputs. What is this an exercise? The circuit doesn't seem to do anything logical. Am I missing something?
Ed
Message 20 of 24
(3,566 Views)
