 StudentNI
			StudentNI
			04-15-2007 05:19 AM
 Maxish
			Maxish
			04-19-2007 10:15 AM
Currently, users do not have the ability to do this.
However, you can take an alternate path which will produce almost the same result using subcircuit parameters
When creating a component, during the model creation stage, append to your the SPICE ".subckt" statement
"PARAMS: param1=xx param2=xx param3=xx...", where "param1" is an arbitrary name and its right hand side value is an arbitrary number
You can use these parameter names alone, or as part expressions, in your SPICE model.
.SUBCKT FOO 1 2 3 4 5 PARAMS: AV=100K VRP=1 VRN=1 RO=10 Rin=10Meg
V1 1 2 DC {VRN}
.ENDS
When you place this component on the schematic, double click it, and press "edit model", you will notice a special instance parameter text box containing the parameters you defined on the .subckt line. You can overwrite the default values for each instance of the component! This has the same effect as the virtual component with the exception of the user friendliness of tabular format.
Cheers,
Alec
04-19-2007 11:17 PM
