Multisim and Ultiboard
How to make a 4 generator of square signals?
Hello, please tell me how to make 4 separate generator of square signals to one generator had a phase of 0 degrees, second 90, third is 180, fourth is 270?
(3,996 Views)
I mean this
But this is Sin-generators, i need the same Square generators, whith separate phase-s
(3,993 Views)
(3,931 Views)
It won't work. I need 4 (four) separate generator square waveform. But! To signal the first generator was in phase 0 degrees. The signal of the second generator phase is 90 degrees. The third signal generator and the phase was 180 degrees. The fourth signal generator 270 degrees.
(3,925 Views)
Did you try using the Pulse Voltage source under the Signal Voltage Sources??
(3,915 Views)
How?... can u show me pls on pic?
(3,909 Views)
Let try to do it, I think that maybe playing with the AC analysis phase we can accomplish that.
(3,899 Views)
