Multisim and Ultiboard
How to make a ring counter in Multisim
How would I do this?
Modify this shift-register in the following manner.  Disconnect the wires on the J and K inputs of the first (left most) flip-flop.  Wire the Q output from the right-most flip flop back to the J of the first flip-flop.  Now, wire the Q' of the right-most flip-flop back to the K of the first flip-flop.  You have just made a ring counter.
a)  CLEAR the shift-register by moving the "C" switch down then up.   Move the DATA switch to logic 0.  Now, move the PRELOAD switch to logic 0.  Note the outputs.  Move the PRELOAD switch back to logic 1.  Toggle the clock "B" two complete times and note the output.  Account for this action.
b)  Toggle the clock "B" two more complete times and note the output.  Account for this action.
c)  Why do they call a ring counter a data re-circulator?
(7,664 Views)
I am not sure as to what you are having trouble with. Could you explain what is giving you trouble and then maybe we can procede from that point. Is it wring the circuit? Do you not understand what the questions want as an answer?
Please let me know exactly where your having problems and I will be able to help you navigate through this.
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(7,656 Views)
