Multisim and Ultiboard
How to manually insert a jumper multisim
hi i want to transfer my circuit to ultiboard but i need a jumper how do i add it on multisim my version does not support automatic insertion.
(13,625 Views)
You can place jumper wires in Ultiboard 12.0 by going to Place>Jumper.
Refer to the following discussion, it explains an alternative if your version of Ultiboard doesn't have the "Place>Jumper" option. http://forums.ni.com/t5/Circuit-Design-Suite-Multisim/Automatic-jumper-insertion/td-p/520570
(13,598 Views)
I also have some problems to place a jumper. I can not connect the jumper which I've placed to the net. Can somebody help me?
Stefan
(13,431 Views)
For a standard 2.54 mm (100 mill) jumper, simply make your own schematic part.
for the footprint, use the one which is used for the HDR1X2 in the master database.
Or even easier: just place a HDR1X2 form the schematic master database.
It doesn't look nice in the schematic, but it does the job...
Good luck
Johan
(13,314 Views)
