Multisim and Ultiboard
How to measure the phase shift using AC analysis?
I have a simple RLC circuit consisting of no more than 4 components. If i hook up the network analyser function to the circuit and read the S11 values, i can see a change in the input impedance and a phase shift when i run it across a range of frequencies.
I am trying to do the same with the AC analysis tool. I've placed a probe on the positive input line. Using the AC analysis i've obtained the input impedance by using the expression mag(V(Probe1))/mag(I(Probe1)). Everything looks fine but i just can't seem to obtain the correct expression to gain the phase shift. All of the values i get out seem to flat line.
It would be great help if someone could point me in the right direction, as i'm running out of ideas.
Thanks for the help.
(7,159 Views)
Hi 08Ultrasound,
You need to measure the voltage phase difference over a load as the voltage source is ideal so will always be in phase.
(7,053 Views)
