Multisim and Ultiboard
How to panelize designs in Ultiboard 10.1
Gentlemen...
Is there a possibility of panelizing 2 or more boards of the same size in Ultiboard 10.1, if so can someone please enlighten me?  Smiley Happy
Brenon
Message 1 of 17
(8,100 Views)
It's not possible, you need Gerbtool to do that function which is no longer bundled with EWB suite. Most of the times the PCB manufacturer will do this for you. If you try to block copy and paste, it automatically updates the refdes values incrementally......It has been discussed before...right now, Gerbtool is the only solution.
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
Message 2 of 17
(8,094 Views)
I remember reading that sometime ago... Thanks Chris!
Brenon
Message 3 of 17
(8,086 Views)
What about doing it as a multi-page design in Multisim and using the Refdes offset feature in the renumbering tool? Obviously you don't get a 3D view of the PCBA, but you can still keep the boards sorted as in R101, R102, R103 on board 1 and R201, R202, R202 on board 2.
____
Ryan R.
R&D
Message 4 of 17
(8,082 Views)
Sounds good in theory, but in practice, if 100 pieces are built, it becomes unruly and also you could possibly start having issues with text over copper which are DRC violations.
NI is very aware of this issue, maybe it will be rectified in the next revision. Maybe they'll chime in and give some idea of where this stands.
Message 5 of 17
(8,065 Views)
As in, silkscreen over copper is a DRC violation? I may be missing what you are getting at.
____
Ryan R.
R&D
Message 6 of 17
(8,052 Views)
Yes, any silk over a copper pad or contact for soldering point, by IPC standards, is a DRC violation. Even though NI doesn't flag for it (which is SHOULD), as the numbers get larger (2 and 3 digit), you risk this error showing up and if you were doing production and/or pick and place population could get quality issues in the soldering of the joint as the silkscreen material is mixed into the joint.....a failure waiting to happen.
Message 7 of 17
(8,043 Views)
But that's all assuming a very dense board population. I thought you were referring to DRC flags being raised by having silkscreen over traces and other masked copper, which is crazy. 🙂 I know from experience in production that 3-digit refdes numbers do not necessarily have to crowd the board, even with pick-n-place assembly lines. Until you have a problem, there is no problem. 😉
____
Ryan R.
R&D
Message 8 of 17
(8,038 Views)
While your point is valid on some levels, most designs are high density. So if you can get away with it, that's cool. Here is what I deal with everday, it doesn't work properly.
Greetz
Message 9 of 17
(8,036 Views)
I would agree with your assessment, given your board. 🙂
____
Ryan R.
R&D
Message 10 of 17
(8,030 Views)
