Multisim and Ultiboard
How to place component underneath (opposite side) a large through hole component?
I have a large through hole component which moves everytime I try to place a component underneath it...on the opposite side of the board! How do I stop this 'Auto-move' function, or, how do I get change the way Ultisim recognizes this component?
(4,278 Views)
Accepted by topic author WillWG
The movement is happeing because of an option called Part shoving. To disable this, go to Design >> Part shoving. If this option is unchecked, the part should not move. You can also lock the part by right-clicking on in and selecting lock. This will allow you to place the part on the other side of the board.
Hope this helps.
Tayyab R,
National Instruments.
(4,277 Views)
I thought there would be a switch somewhere like you've described, I just couldn't find it. Thanks for the help.
(4,250 Views)
