Multisim and Ultiboard
How to plot the rms voltage from a probe in transient simulation
Hello!
I am trying to analyze my circuit and in doing that I want to run a simulation for say 30 seconds and plot the ac voltage at a certain point in the circuit against time. The setup includes one ac source with a fixed frequency and one that I want to vary. I could not find a way to do this with the AC Sweep function so I replaced the source that should be varied with a voltage controlled oscillator that I supplied with a sawtooth wave. Now I would like to run the simulation and get a plot of the rms voltage at a point against time. I tried transient simulation but I cannot find where I decide which out of all the values the probe displays the plot does. It seems to only be able to take the instantanious voltage. Does anyone know of a way to plot the ac rms or p-p voltage?
David
(2,639 Views)
Hello davham,
I suggest you to use "Parameter Sweep" analysis type.
In this forum I have already showed and explained how it works.
__________________________________________
The best way to thank, is to give KUDOS
(2,545 Views)
