Multisim and Ultiboard
How to remove a created board?
Hey all..
I'm wondering how can I delete a board which I created with the board wizard in Ultiboard..?
Thanks!
Felix
(3,288 Views)
Hi Felix,
You can modify (delete) the board outline by selecting the Board Outline layer in the Layers tab in the Design Toolbox. Note that the Board Outline layer is selected in the image below. Once you select the layer, you will be able to select items (lines, rectangle, etc) on that layer.
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(3,261 Views)
