Multisim and Ultiboard
How to separate the source and the measured current
Hi Everybody,
I'd like to know if there is some way to separate the source and the measured current and just writte an mathematical expression to make a dependence between the source and the said parameter. Thanks in advance.
(5,246 Views)
Hello Sergio Sobrera,
Can you explain better your doubt?
regards,
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(5,205 Views)
Sure,
Here is the deal:
I'd like to build a circuit with dependent sources, but instead of connecting the sense of current/voltage, I'd like to know if there is a way to writte a sentence for the source which is dependent of a parameter.
For example:
In this circuit I just wrote an expression for the source and its respective parameter. (8*Io).
(5,179 Views)
Typically Spice simulators handle that situation by placing a zero voltage independent source in series with the 5 ohm resistor. The current through that source then becomes the controlling current for the dependent source. If you need a more complicated expression than a constant multiplier, look at the non-linear dependent sources (B devices in Spice 3).
Lynn
(5,165 Views)
